So is MS_CONFIGURATIONOPTS no longer works the way it supposed to starting from U17? The variable usage is still available in U17 help:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v21/en/GUID-91AE65DE-BC4A-398D-3741-E98D25ACFDC7.html
Allows you to control the creation or selection of WorkSpaces and WorkSets from the respective drop-down lists in the Work page. Following are the options for this configuration variable:
How can CAD admins reinstate the function of MS_CONFIGURATIONOPTS in U17?
Best regards,
Tuan Le
Bug 902810 has been logged for this issue.
Thanks for the update Leonard.
In U17, to disable the option Create WorkSpace and WorkSet, place this variable in the CFG file WorkSpaceSetup.cfg (not in Standards.cfg).E.g., in the CFG file C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaceSetup.cfg add the lineMS_CONFIGURATIONOPTS = DisallowCreatingWorkSpace,DisallowCreatingWorkSet
Thanks for the update Kees, however that configuration variable has no effect on the new "Manage Configuration" dialog introduced in U17, which allows anyone to go ahead and create their own configuration/workspace/workset.
The ability to hide or disable the Manage Configuration is being addressed most likely in the next release.
