So is MS_CONFIGURATIONOPTS no longer works the way it supposed to starting from U17? The variable usage is still available in U17 help:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v21/en/GUID-91AE65DE-BC4A-398D-3741-E98D25ACFDC7.html
Allows you to control the creation or selection of WorkSpaces and WorkSets from the respective drop-down lists in the Work page. Following are the options for this configuration variable:
How can CAD admins reinstate the function of MS_CONFIGURATIONOPTS in U17?
Best regards,
Tuan Le
Hi Kees,
Just wondering if this can be done in U17.1 that's just been released?
Hi Tuan, no, not in U17.1 .
Then can I get some information on the defect 976048 listed in the resolved issue list for U17.1?
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v22/en/GUID-D2BD6E6D-C524-4E9F-80F1-7199D979C9B7.html?
This worked for me - moving MS_CONFIGURATIONOPTS to our WorkSpaceSetup.cfg for MicroStation CONNECT - which we have configured on the network (with our workspaces)!
We have not been moving users to MS-CE UD 17 due to this issue!
I tried this suggestion - and it works for me (sorry I did not see it sooner)
Thanks Kees van Prooijen!
It's a different bug number than Leonard posted but the MicroStation Update 17.2 Defects Resolved lists:
Bug:1028255Fixed issue where MS_CONFIGURATIONOPTS is ignored when set at Organizational Level
I'm assuming this is the bug affecting those that fixed it by moving the setting to WorkSpaceSetup.cfg
Defects resolved list is here:
Resolved issues for MicroStation CONNECT Edition 17.2 - MicroStation Wiki - MicroStation - Bentley Communities
