Good day,in MicroStation CONNECT EDITION U17, the *.DGN version 7 format is missing in the SAVE AS / EXPORT dialogDoes anyone know how to enable this data export option?
found this in the delivered HELP under "New and Changed>Deprecated Features"
V7 Workmode - Saving As V7 and Editing V7 files. (V7 files can be opened as Read-only).
Timothy Hickman
Main: 877 627 3772|
Answer Verified By: Melissa Hook
OK, I understand,but saving a drawing from v8 to v7 should be possible.But in my MicroStation, the "Microstation V7 DGN" format type is missing from the SaveAs dialog.See picture in my first question
Just to expand on what Tim Hickman has mentioned, the V7 DGN file format was replaced with the V8 DGN files format over 20 years ago. There are not many requirements or other software packages that still rely upon this old V7 DGN file format. This ability to save back to this old format has now been deprecated, as explained in the Help Documentation. You can still open these old V7 DGN files and save to the V8 DGN file format.
History of MicroStation
New and Changed in MicroStation CONNECT Edition Update 17
Hello, thank you for your reply.I have been working with MicroStation since version 95' and I was present as a user during the transition to the DGN v8 format.And precisely because of the aforementioned backward compatibility with another system used by our company, I need to convert the drawings created in version v8 to the older version v7.Our company has currently upgraded MicroStation V8i SELECT to the latest CONNECT edition U17 and at that time we found that the option to save to v7 format is not available.Hence my question how to get this functionality back.I'm sorry, but I'm not looking for a reason why it doesn't work, but a way to make the option to export to DGN v7 operational.Anyway, thanks for all the ideas and replies
I would recommend keeping a version of MicroStation around that will allow you to save back to the V7 file format (pre update 17).
Bentley has no obligation to keep this functionality and has made the decision to deprecate this option.
In the meantime, Company wide, I would suggest making a workflow towards getting off this old file format. Choosing to remain has no guarantees.
