Hi! I am trying to find the site configuration file of my Microstation V8i SS10 system. I was able to find a path from the _USTN_SITE variable, and assumed that's where the site configuration sits. However, how to find the file name of the site configuration? I search around the system variables but couldn't find a clue.
If you open a file in MicroStation and use the key-in $ %explorer $(_USTN_SITE), Windows explorer will open in the location pointed to by the variable. In this folder you will see the configuration file(s). For a default install you will see the config file Standards.cfg.
MicroStation will read all config files in this location see also this Wiki
Answer Verified By: Sui Huang
running a "debug" on your configured MicroStation will show you what configuration files and variables are set at the SITE level.
https://communities.bentley.com/products/microstation/w/microstation__wiki/11081/how-to-quickly-generate-a-debug-file
Timothy Hickman
Main: 877 627 3772|
Carl is the man. Read that wiki he linked. Critical to understand the order these files are processed in.
Hi Carl, thank you! I after reading the Wiki you sent I understand how it works now.
Just want to confirm another minor thing: I entered "%explorer $(USTN_SITE)" in the key-in. The Windows explorer opens with the default windows local location, but not where _USTN_SITE points to. Does it mean the system variables cannot be resolved in the key-in utility, and the path needs to be entered explicitly?
Hi Tim,
Thank you, I tried and this way should work. The debug output gives all the details.
Sui
