Hi! I am trying to find the site configuration file of my Microstation V8i SS10 system. I was able to find a path from the _USTN_SITE variable, and assumed that's where the site configuration sits. However, how to find the file name of the site configuration? I search around the system variables but couldn't find a clue.
Perhaps a typo was made when you entered the Key-In you mention "%explorer $(USTN_SITE)", which is missing the '_' underscore in front of the variable _USTN_SITE
Hi Carl,
I tried again with the typo fixed, but still doesn't work. It also only opened the default local path when I tried other variable names for paths.
It worked as expected when I tried "%explorer C:\"
I think this issue wouldn't brother me, because I can always look at the path value from the configuration window.
Thank you!
Sui
