I have been using MicroStation CONNECT since its first release. I've had no problems with installation or configuration until Update 17.
I'm attempting to install and use Update 17 with a custom configuration location. That location was in use successfully with Update 16. I specified the configuration location (L:/Bentley/CONNECT/LA Solutions/) during installation.
When I start MicroStation Update 17 I see this page...
When I click the WorkSpace button, I see this...
MicroStation can't see my existing workspace or worksets.
When I click the Create WorkSpace button, MicroStation crashes. Clearly, I did something unexpected during installation. Can anyone provide inspiration?
I've attempted to install Update 17 several times. On previous failures, I deinstalled and returned to Update 16, which contined to work properly. This latest time, I uninstalled Update 16 and cleaned out the configuration folder (C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration) before installing Update 17.
Have you tried the Manage Configuration under Configuration? Add a new config and have it point to where your stuff is.
Bob Rayner said:Have you tried the Manage Configuration under Configuration?
MicroStation CONNECT Update 17 crashes when I attempt that.
Yea, guessing it's just another bug. You might try editing the file shown below.
I've removed U17 and gone back to U16 for that very reason.
I don't have time to figure this out for now.
Rod WingSenior Systems Analyst
You might find this discussion helpful.
https://communities.bentley.com/products/administration/f/product-administration-forum/232341/msce-u17-manage-configurations-and-using-_ustn_custom_configuration-variable
