Hello
I want to learn how to get Bentley software (MicroStation, inroads, open roads, open-bridge, ECT.. ) set up on the machine. and how can I adjust the configurations according to the DOT seeds ,files, libraries, and so on .
Is there training to do that somewhere?
Hi Ala,
This is a SYNCHRO forum. Please reach out to specific product communities for additional information - communities.bentley.com/products
I'm sorry. I did not pay attention to that.
Thank you for your reply
Many of the DOTs I work with make their workspace available through their CAD Support departments. You may be able to download those and install them into your C:\ProgramData\Bentley\OpenRoads Designer...\Configuration\ to the proper subdirectories.
I also believe that the Bentley Learn Server may have courses on setting up configurations, to help you integrate the DOT standards into your workflow.
MaryB
most DOTs will include a Readme or PDF with the steps to set up their configurations.
If not - I would contact the DOT directly and ask for guidence on how they want the configuration installed (not all DOTs will be configured in the same way)
Timothy Hickman
Main: 877 627 3772|
As Tim pointed out most DOT's provide some type of documentation on installing or setting up their Workspace/Configuration. First you'll want to confirm which version their standards are for and follow their instructions.
As far as learning to configure MicroStation there is training available on our Learn site:
https://learn.bentley.com/app/Public
