I am trying to setup a number of other AGENCY workspaces for ORD 2022 R1 which is the first version to include the Manage Configuration tool. A few of these are proving problematic and I need to evaluate what is occurring during their processing. Are there command line switches that will result in one of the Manage Configuration Workspaces to load that I can use with a -debug command line switch. And can that same command line switch be used with the Configuration Explorer?
There are several ways to accomplish this, if you just want it for you the easiest is to create, or modify, your user association.
There are other ways to accomplish this if you need other users to be able to do this too without going through all those steps. If you need those, ask over in the ProjectWise forum and I'll post there.
I'll tell you straight up: The debug files from managed workspace are pretty much worthless compared to a normal debug file. It doesn't give a list of files that it opens and processes, instead it just says it's open a single cfg file. It dumps everything from that config into the debug file then adds the summary at the end. Only additional info you get is the level at which the variable is being set. That's occasionally useful, but 90% of the time I just open the product do the "show configuration" key-in and use that file instead of the debug file.
When I really want to puzzle out what's going on is:
Everything I’m trying to do here is outside of ProjectWise. We actually have a custom application predefined in ProjectWise to make it easy for users to create an msdebug.txt file to assist when troubleshooting issues.
But my current efforts with these other agencies is just from Windows with all local workspaces and files.
And I found something interesting in one agencies workspace. They define a custom variable in every CFG file. It’s the same variable and they use the append (>) operator and the value is the name of the CFG file. This results in one variable that acts as a log file listing each CFG in the order of processing. I have begun adopting this but with partial path file names so that there is no confusion as to where the file was read from.
This will be even more useful in ProjectWise but once implemented will mean I use an MSDEBUG.txt file much less often.
Ah, we do that as well (we include CSB in that variable too). I've also seen varaibles set at the beginning and end of each config file:
_WorkSpaceSetup_Start = 1
... workspacesetup here ...
_WorkSpaceSetup_End = 1
If you want to force MicroStation to do a debug with a particular configuration you'll have to add in all the settings to a shortcut icon. For example:
microstation.exe -wkWorkSpaceName -wwWorkSetName -debug
You need to specify both a WorkSpaceName and a WorkSetName
Hi, as far as the configuration explorer can not manage the new configuration managerI want to generate a debug file for a specific : (just like the config explorer should do)
application (OpenBuildings designer) "C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\OpenBuildingsDesigner.exe"configuration (ConfigurationName) -??WorkSpace (WorkSpaceName) -wkWorkSet (WorkSetName) -ww
-debug
haw to build this shortcut?is a space needed after -wk or not-wk WorkSpaceNameare the " needed ? where to open and close the " "
please give me a correct shortcut target ( and start in)
No space after -wk -ww -wr, use quotes around the workspace/workset name if they have spaces in them.
"C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\OpenBuildingsDesigner.exe" -wr"Configuration Path" -wk"WorkSpace Name" -ww"WorkSet Name" -Debug
If you specify a WorkSpace name, you have to specify a WorkSet name for it to work.
