Adding a separate post as this has come up in multiple threads.
To hide Manage Configuration edit ConfigurationSetup.cfg on each local machine (or deploy an edited copy of the file as discussed elsewhere) so the value of _USTN_USER_CONFIGURATION = <pathToCustomConfiguration>
The result is shown below, the Manage Configuration option is not displayed. (There may be other nuances to this setting, if so I will post additional information.)
Thanks Marc. What's the relevance of the configuration.xml in this instance then? Is it still used or is it completely bypassed?
Bypassed as far as I can see, I'll confirm that as I discuss with the devs.
configuration.xml populates the Mange Configuration tool, so I would expect it to be ignored.
Marc
Thanks for the update Marc.
Further notes:
_USTN_USER_CONFIGURATION_LABEL = <My Label>
does not have any effect; it should relabel the occurrences of 'User Configuration' in the UI. Development have determined that this works as designed.
In U17.1 MS_CONFIGURATIONOPTS does not work when _USTN_USER_CONFIGURATION is set; bug 769892 has been filed regarding this problem.
