(Test config is from MicroStation CONNECT 10.17.01.58 but pretty sure it happens in everything probably back to the beginning of config files)
TL;DR: Don't assign a variable, or part of a variable, to itself using $(VARIABLE), either use additional variables or use ${VARIABLE}
Just drove myself crazy for a couple of hours debugging a config file thought I'd post it here in case someone else runs into it.
I wanted to take a directory like: C:\Folder1\Folder2\Folder3\
I wanted to do something with each folder name so I wrote a config to extract the name, get the parent directory, extract that name, get the parent directory, etc...:
TEST_PATH = $(_USTN_SYSTEMROOT) %echo test: =>$(TEST_PATH)<= %echo LAST_DIR = lastdirpiece($(TEST_PATH)) PARENT_PATH = parentdevdir($(TEST_PATH)) %echo lastdir1: =>$(LAST_DIR)<= %echo parent1: =>$(PARENT_PATH)<= %echo LAST_DIR = lastdirpiece($(PARENT_PATH)) PARENT_PATH = parentdevdir($(PARENT_PATH)) %echo lastdir2: =>$(LAST_DIR)<= %echo parent2: =>$(PARENT_PATH)<= %echo LAST_DIR = lastdirpiece($(PARENT_PATH)) PARENT_PATH = parentdevdir($(PARENT_PATH)) %echo lastdir3: =>$(LAST_DIR)<= %echo parent3: =>$(PARENT_PATH)<= %echo
This produced:
test: =>C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\<= lastdir1: =>Default<= parent1: =>C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\<= lastdir2: => parent2: => lastdir3: => parent3: =>
So the first extraction works, but then the 2nd and 3rd where I overwrite the variables doesn't. After much hair pulling I finally remembered the difference between $() and ${}. Basically $() means "don't actually resolve this variable yet, just keep the $(variable) string and replace it later" while ${} means "use the value of this variable as it exists right now!"
Now I rewrote my tests as:
TEST_PATH = $(_USTN_SYSTEMROOT) %echo test: =>${TEST_PATH}<= %echo LAST_DIR = lastdirpiece(${TEST_PATH}) PARENT_PATH = parentdevdir(${TEST_PATH}) %echo lastdir1: =>${LAST_DIR}<= %echo parent1: =>${PARENT_PATH}<= %echo LAST_DIR = lastdirpiece(${PARENT_PATH}) PARENT_PATH = parentdevdir(${PARENT_PATH}) %echo lastdir2: =>${LAST_DIR}<= %echo parent2: =>${PARENT_PATH}<= %echo LAST_DIR = lastdirpiece(${PARENT_PATH}) PARENT_PATH = parentdevdir(${PARENT_PATH}) %echo lastdir3: =>${LAST_DIR}<= %echo parent3: =>${PARENT_PATH}<= %echo
This time it worked:
test: =>C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\<= lastdir1: =>Default<= parent1: =>C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\<= lastdir2: =>MicroStation<= parent2: =>C:\Program Files\Bentley\MicroStation CONNECT Edition\<= lastdir3: =>MicroStation CONNECT Edition<= parent3: =>C:\Program Files\Bentley\<=
This issue isn't because of the parentdevdir, same thing happens anytime you use $() to assign the value of a variable (or part of the value) to itself:
TEST_PATH = $(TEST_PATH)
even indirect assignments will have issues:
TEST_PATH1 = $(_USTN_SYSTEMROOT)
TEST_PATH2 = $(TEST_PATH1)
TEST_PATH1 = $(TEST_PATH2)
even replacing that last line with:
TEST_PATH1 = ${TEST_PATH2} ALSO FAILS because the "value right now" of TEST_PATH2 is still $(TEST_PATH1) with regular ()
Because resolution is delayed this line says "Assign TEST_PATH to TEST_PATH once it's resolved" well that's never going to resolve because it's a big circle.
