The workspace/workset rabbit hole has no end.
I'm starting with one client. Trying not to edit those client configs. This client comes with a workset template - folder, CFG & DGNWS.I wanted to see if that template is actually what is used to create new worksets under that client.
Apparently, it's not.
I was able to create a new workset. I selected "Create Workset", gave it a name and selected the template I would like to use. It created a folder, CFG & DGNWS in the proper location. But the folder doesn't include the files from the template folder and the CFG is not the same as the template CFG (far more generic, not even close). It would appear that the template being used is not the template I selected? Or is the CFG file unrelated to the template workset?
I am getting lost in the CFG variables, so I'm sure I have something crossed up. Can anyone make a suggestion to straighten me out?Thank you.
I think you only may be missing the underscore in front of USTN for both on Line 5
Answer Verified By: MaryB
We have a winner! I've been looking at this for way too long...
MaryB
I spoke too soon. it was the end of the day, and I was too eager to be done.
I have corrected the code:
_USTN_TEMPLATEWORKSETNAME = TDOT_RDWY_TEMPLATE _USTN_WORKSETDGNWSTEMPLATE = $(_USTN_WORKSETSROOT)$(_USTN_TEMPLATEWORKSETNAME).dgnws _USTN_WORKSETTEMPLATE = $(_USTN_WORKSETSROOT)$(_USTN_TEMPLATEWORKSETNAME)
And I can see my template when I try to create a new workset. However, only the CFG gets copied to the new workset name - the DGNWS and the Template folder do not get reproduced. Without a DGNWS there is no workset available to select.
The template named has a CFG, a DGNWS, and a folder:
So I'm not missing anything?
Just a guess... did you rename your workset template? I would clone the original provided template each name change, just in case...
Yes...I did...OK, I'll see about getting "clean" versions created from the original provided worksets.This is a real pain if you can't even rename files.
