[ORD/CONNECT] Workset template?
The workspace/workset rabbit hole has no end.
I'm starting with one client. Trying not to edit those client configs. This client comes with a workset template - folder, CFG & DGNWS.
I wanted to see if that template is actually what is used to create new worksets under that client.
Apparently, it's not.
I was able to create a new workset. I selected "Create Workset", gave it a name and selected the template I would like to use. It created a folder, CFG & DGNWS in the proper location. But the folder doesn't include the files from the template folder and the CFG is not the same as the template CFG (far more generic, not even close). It would appear that the template being used is not the template I selected? Or is the CFG file unrelated to the template workset?
I am getting lost in the CFG variables, so I'm sure I have something crossed up. Can anyone make a suggestion to straighten me out?
Thank you.
  • Since I can't just copy and rename worksets (DGNWS), I imagine I still need to go through the actual "Create Workset" dialog.
    No, if the dgnws doesn't exist the first person to open the workset will create it by copying the defined dgnws template file. You can define a template for JUST the dgnws using _USTN_WORKSETDGNWSTEMPLATE. That variable can point to any file at any path. It will be copied to either the default location or what _USTN_WORKSETDGNWS points at.
    Person that creates the file has to have read/write on the destination, but that's always me currently so hasn't been an issue.
  • Person that creates the file has to have read/write on the destination, but that's always me currently so hasn't been an issue.
    Every user will need read/write access to the dgnws file if you want them to be able to edit the WorkSet Properties, and add sheets to the Sheet Index. That's the main reason we remap the location of _USTN_WORKSETSROOT so that everything under _USTN_CUSTOM_CONFIGURATION can be read only except for the admins.
    Rod Wing
    Senior Systems Analyst
  • That sounds as if I don't need to create a DGNWS to create a workset?
    Would I be able to set _USTNWORKSETDGNWSTEMPLATE in the workset CFG? That would certainly simplify one thing...And it suggests that I could bypass the "Create Workset" dialog entirely, as long as I could generate the workset CFG any other way.
    Also...Is there a way to isolate the workset templates from the regular worksets? If I do need to use the standard "Create Workset" dialog, I would like it to just show my templates for the workspace, not all of the worksets for the workspace.
    _USTN_WORKSETTEMPLATE is for a single file. If I need to use the standard dialog, I need them to be able to select from a list of client templates for the workset, but I wouldn't want to bog that list down with all the rest of the workspace worksets.
    Of course, if I all I really need to do is create the CFG file, that is fortunately moot.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • I'm not sure if you can set _USTN_WORKSETDGNWSTEMPLATE in the workset.cfg, I want to say it has to be at the workspace or lower but it's been a long time since i tried and I don't remember the results. Mine is set at effectively the organization level.
  • Oh, I just remembered when ORD (or other product) is opened it doesn't just create a DGNWS for the current workset, it actually creates one for every .cfg in _ustn_worksetsroot that doesn't already have one, even if you don't open that particular workset. So if you take a template file, rename it to a .cfg file and start editing it, if somebody else opens any other workset in that folder it creates the dgnws for your cfg from whatever it's template is.
    I think we filed this as a bug but I can't remember if Bentley agreed. Currently we say to keep the .template part until you're actually done editing it.
