Hi Everyone,
I am trying recently to learn a little bit more about MicroStation workspace, workset and role configuration files. I am currently using MicroStation Connect Edition Update 16 (Version 10.16.01.56).
My goal is to create a role specific (for Electrical, Civils, Telecomms disciplines) libraries for the following:
- Item Types
- Report Definition
I was able to load role specific Item Types library and Lookup table by adding the following lines into my role configuration file:
MS_DGNLIBLIST_ITEMTYPES > $(_USTN_WORKSPACEROOT)Roles/Electrical/Dgnlib/*.dgnlib ITEMTYPE_LOOKUP > $(_USTN_WORKSPACEROOT)Roles/Electrical/Itemlib/KAW_CarbonAssessmentLookup.xlsx
The MS_DNGLIBLIST_ITEMTYPES is only loading Item Types and does not load Report Definition which was saved in the same DGNLIB as Item Types. Is it possible to load report definition from the role level, so that only role specific reports will be loaded?
Please note that I am still learning, and I am not sure whether I loaded role specific Item Types and Lookup Tables in the right way. So, I appreciate your support.
Hi Rod,
Thanks for your comment. I have tried to switch roles and you are right, it does not work properly. I noticed that when I changed the role the DGNLIB from previous role were loaded as well. So, the list of DGNLIB was growing everytime I switched to new role. Once I close MicroStation and switch to specific role again, I could see the DNGLIB from that specific role only.
However, it still does not load the organisation DGNLIB when the following line to Role.cfg is added.
MS_DGNLIBLIST_ITEMTYPES < $(_USTN_WORKSPACEROOT)Roles/Electrical/Dgnlib/*.dgnlib
Also, if any following line is added to Role.cfg file, MicroStation does not load any role specific DGNLIB.
MS_DGNLIBLIST > $(_USTN_WORKSPACEROOT)Roles/Electrical/Dgnlib/*.dgnlib
or
MS_DGNLIBLIST < $(_USTN_WORKSPACEROOT)Roles/Electrical/Dgnlib/*.dgnlib
MS_DGNLIBLIST = $(_USTN_WORKSPACEROOT)Roles/Electrical/Dgnlib/*.dgnlib
