I posted this to the MicroStation Ideas portal at Allow comma separated config variables to | MicroStation Ideas Portal (aha.io) but thought I'd drum up some votes for it here.
Idea:
Variables like MS_LEVEL_SYNC_ATTRIBUTE_LIST and MS_LEVEL_EDIT_ATTRIBUTE_LIST accept a comma separated list of values. I'd like these variables to also accept a semi-colon separated list.
Reason:
With a semi-colonseparated list we can build these variables like:
MS_LEVEL_SYNC_ATTRIBUTE_LIST = OverrideSymbology # Force sync ALL Overrides MS_LEVEL_SYNC_ATTRIBUTE_LIST > ByLevelSymbology # Force sync ALL ByLevel settings MS_LEVEL_SYNC_ATTRIBUTE_LIST > Plot
With this method of setting the values it's both easier to read (less error prone) and easier to document each individual setting
Oh, yes! This would be SO much easier to keep track of. And easier to define in more than one instance (client vs. org.)
MaryB
