We have multiple mvba's loaded at the workspace and organisation level. And then we load some specific mvba's at the workset level.
For one workset, I need to remove a specific mvba that is loaded in the workspace.cfg file. If I undefine MS_VBAAUTOLOADPROJECTS in the workset.cfg then I lose all the mvba projects.
In the workset.cfg file, is it possible to unload a specific mvba?
Connect versions of
When you receive any messages of this sort in relation to communications through the Connection Client it is always worth having a look at the Bentley Cloud Services Status page to see whether there may be something happening at that time.
It is also worth having a look at the following article explaining the Failsafe Mode that can be implemented if this happens.
If you have major concerns with any outages posted to this page you can always call us on your local regions phone number.
Contact Us
The fail safe mode worked for the CAD applications, but it didn't help when trying to access files in PW hosted on a Bentley cloud server using IMS authentication.
The tech support said the Bentley engineers were busy working on getting the issue resolved, but did not have a timeframe for when we would be back online.
That's weird I was able to login to our hosted site using IMS authentication even though I got the notice about Fail Safe mode being active (I'm using Connection Client 11.00.05.50). But I tried 6 hours after your note so maybe they fixed that part of it first.
Hi Michael, just as an FYI on this topic, we are working on improving the resilience of the IMS system, I understand changes will be implemented as this year goes on. Please excuse my vagueness, this is not my specialist area, I just wanted to offer some reassurance that we are working on it.
Marc
