Microstation Connect Edition can't find Workspace from NYSDOT. Followed instructions from NYSDOT, but still not showing workspace and workset options. I have seen some answers about this problem, but still couldn't figure out.
I think you may have went one folder too far when pointing the _USTN_CUSTOM_CONFIGURATION to the workspaces folder. You only need to go to the Configuration folder.
Also - if you are placing the NYSDOT workspace in the delivered configuration, then it should not need to use the _USTN_CUSTOM_CONFIGURATION. The software should already see the delivered configuration.
FYI: This is not a recomended workflow. It is recomended that you create a separate folder structure for the custom configuration.
Timothy Hickman
Main: 877 627 3772|
Ah, yes I think Tim's correct.
Easiest fix might be to change your ConfigurationSetup.cfg so that:
_USTN_CUSTOM_CONFIGURATION = $(_USTN_INSTALLED_CONFIGURATION)
or remove the _USTN_CUSTOM_CONFIGURATION altogether
I did have updates from connect client, and it works now. Thank you!
