I have happened across this key-in INPUTMANAGER and I need to know more about customising the popup menus with it because they are faaaaaaaar superior to the ribbon groups I have been suffering with.It appears to be associated with the V8i mode - ToolBoxINPUTMANAGER MENU gives this popup
AndINPUTMANAGER MENU TASKSWill pop up with the current Task List selected either in the associated toolbox
or the key-in
TASK MENU
There is literally two mentions of this Key-In in the CONNECT literature and it is completely absent from the Key-In Index https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v22/en/GestureAssignmentsFlicks.html
As you have noted, this key-in INPUTMANAGER is associated with the old MicroStation V8i Tasks menu system. There is still the capability to Customize the old V8i Tasks menus and have these stored in your DGNlib file. The following documentation regarding the old Tasks menu customization is available in the Help Documentation of CONNECT Edition.
Main Tasks
Working with Main Tasks
