Function Key Menu File is missing from preference directory
I created a function key menu seed file using MS_FKEYMNUSEED. When I open ORD, the desired function key menu loads and works as expected, but I do not see the function key menu file (JHefner.funckey.mnu) in my preference folder. Can anyone shed any light on this? How is the function key menu working if the file does not exist in the directory specified by MS_FKEYMNU?
Open Roads Designer CE - 2021 Release 2 Update 10
Version 10.10.21.04
Parents Reply Children
