MicroStation v10.17.02.61 and some machines on slightly older versions
I have installed the Autodesk NWC export from MicroStation on my computer and it does the job required, I now need to get this to work for all the other users. The method of installation I used is covered here.Exporting Navisworks file from OpenBuildings Designer
I do not want to copy the files to the program files folder on every computer due to security implications.
I have tried copying the files to our network configuration in the MS_MDLAPS folder but when someone else runs the MDL it can't find the supporting files all in the same foldersI set The variables as below but still does not work.MS_ADDINPATH > $(_USTN_ORGANIZATION)mdlapps/MS_ADDIN_DEPENDENCYPATH > $(MS_ADDINPATH)nwcreate_data20
Is there a way to overcome this issue.
Regards,John Davidson
If you have a shared network location you should be able to place the mdl and associated dll files on the network and edit the MS_MDLAPPS variable to search that location.
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v23/en/GUID-32665AF4-0804-AA15-218C-28CFEDBC19DA.html
Running MDL Applications
the latest NavisworksExporters installer will need to be run on all PCs for the exporter to work properly. Prior versions of the NavisworksExporters allowed for copy/paste required files between PCs without running installation. But newer versions required proper installation of the exporter as well as copy/paste required files for OBD to export correctly.
I could be wrong, but the last time we tried that with NavisworksExporters2023.exe, we found that simply pointing to the 4 required files/folders doesn't work without running the installer beforehand.
I have resolved this by adding into the configuration the variable pointing to where Windows can find .dll files. as well as the MDL app being in the MS_MDLAPPS path.
MS_MDLAPPS < $(_USTN_ORGANIZATION)mdlapps/ # Organization MDLAPPS
MS_LIBRARY_PATH > $(_USTN_ORGANIZATION)mdlapps/ # Finds dlls associated with MDL's
