How can convert files from MicroStation connect edition (Update 17) to MicroStation V7in the old version, i can export through save as
Saving As V7 and Editing V7 files has been deprecated in Update 17.
V7 files can be read but we no longer save back to V7.
Please can you advise of the reasons that you need to save as V7?
Marc
I need it to export to Qgis to create a shapefile format. the Qgis does not accept V8 files only v7.
If it provides sufficient fidelity you could export DGN to DXF, Qgis will import that.
Otherwise our solution would be DGN to SHP in Bentley OpenCities (formerly Bentley Map), the SHP into Qgis.
Thank you
