I am currently using Microstation CONNECT 17.2, but I've experienced this issue with previous versions of CONNECT. I've also used OpenRoads Designer 2021 R1 - 2022 R3.
I have created a customized ribbon in order to reproduce barmenus that were developed and used in Microstation v8i. In order to migrate the menus (.mdf files) a new ribbon tab was created in a new .dgnlib. Next, I created 3 Tool Group panels with drop-down menus. This allows me to switch the menus shown in each of the groups. In the group that contains the actual tool menus, I created the tool buttons using the New Menu Item. The tool contains a title for the tool and a keyin that is run when the item is selected.
My question is why can't these tools be moved out of their sub-menus they were created in?
ex. If I want to move Bridge Parapet out of Existing Bridge and into Proposed Bridge I am not able to perform that operation.
Also, if I want to create a new menu and reuse Bridge Parapet I am not able to select it from the "Choose components from" column to add it to the new menu
The only difference I can find is the built in tools have a source
Where the custom ones show Source; Unspecified
I'm typing this from a phone, so I can't test it, but for your first example: try moving bridge parapet >between< the items, (for example footing and substructure) so you get a little line with a "+" at the end. That way you can move your item. Then you can also change it's position in the sub menu by dragging it higher or lower in the list.
I hope that i understood what you are asking. Ignore this if it is irrelevant.
Attempting to drop it in the Proposed Bridge menu is the same as trying to insert it between 2 existing sub-menu items. It does not allow it either way.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
It just ain't that flexible. The item Bridge Parapet is tied/locked to Existing Bridge at time of creation, despite what you see on the screen.
Bob Rayner Yes, that seems to be the case.
As bad as Connect is, I was just happy I was able to add a bit of Ribbon for common tasks not available in Task Navigation interface (which I use cause it's minimal/efficient). It would be nice if you could at least cut and paste those items you want in a different branch of Ribbon.
