Starting the task of reconfiguring Microstation V8i
We are at a point to where the Bentley system has been mismanaged if you will for too long.  We are going through an effort now, to clean up the application.
So, I have been asked to help get this under control.  So, Im looking for a spreadsheet ( that someone may have readily available) which contains all the various configuration variables? in short form, or long.
Is there such an animal, or shall I build one through the configuration manager?
We use all the Building Products as well as ProjectWise.  So, if I could get all of these, that would be COOOOOLLLLL...
