File Type
It appears that the file has to be recognized as a Bentley Microstation Configuration file type.
I copied a config file in the config/system folder, and cleared it out, and added my variable name & valiue.
So, How to create a Bentley Configuration with the proper file type association.  YOu used to be able to make a text file with the ."cfg"
