The following error occurs in extract and install installation package. What's the problem and how can I fixed it.
Please provide version information.
Chris
I have download a trial version of MicroStation V8i (SELECTseries 3) and installed at my notebook with Window 7 Home Premium Service Pack 1 and IE10. Is it the setting of IE10 causing the problem? Thank you.
Chris,
That information provides enough for me to ask you for the log files created during installation. The following is from the Quickinstall Guide portion of the ReadMe:
NOTE: Log files - When you install the application following log files are created:
Dear Chris Mark,
I run the downloaded file "MicroStation_V8i_SELECTseries_3_30-day_evaluation.exe" and the extract package form is poped up. When I change the extract floder by clicking the folder icon or press the OK button to extract package then the error occurs! I think the installation was never been started and log file was not created!
What can I do?
A few other things that come to mind... what is the locale or regional setting of the OS you are trying to install the English version of MicroStation V8i (SELECTseries 3) on? Also, are you logged in to your computer with an account that has Administrator rights? Have you taken a look at the QuickInstall Guide (in the ReadMe) to see if there are any other things identified in it that you might want to look into? The ReadMe is online starting on ftp.bentley.com/.../readme.htm
