Configuraton %if (file exists)
This file does exists
$(_USTN_USER)$(USERNAME)/hbc.upf)
This:
%if exists ($(_USTN_USER)$(USERNAME)"/hbc.upf")
MS_UserPREFSEED =  ($(_USTN_USER)$(USERNAME)/hbc.upf)
%else
MS_UserPREFSEED = ($(_USTN_USER)/hbc.upf)
%endif
or this
%if exists ($(_USTN_USER)$(USERNAME)/hbc.upf)
%else
%endif
$(_USTN_USER) = Q:\workspace\users\
$(USERNAME) = h1234
if  Q:\workspace\users\h1234\hbc.upf exists why does the if statements above not set MS_UserPREFSEED = Q:\workspace\users\h1234\hbc.upf
Any ideas would be appreciated?
Parents Reply
  • Tim,
    Thanks for your input. I was able to get the syntax working as expected. It helped to change one of the hbc.upf to hbc1.upf. I then search all my config files for MS_UserPREFSEED and made sure that it was set only in my site.cfg file. I change the syntax to the following:
    %if exists ($(_USTN_USER)$(USERNAME)/hbc1.upf)
    MS_UserPREFSEED =  $(_USTN_USER)$(USERNAME)/hbc1.upf
    %else
    MS_UserPREFSEED = $(_USTN_USER)/hbc.upf
    %endif
    I have been working on this issue when time permits for sometime. Thank you so much!
    Roland
    V8i SS4 v.08.11.09,829
    AECOsim BD V8i
    Answer Verified By: Roland
