Seem to be getting a APPCRASH in Windows Explorer when doing a search. The crash indicates Fault Module Name: DgnFileIO.dll version 1.0.1.22. Any ideas as to why a Windows Explorer search would indicate DgnFileIO.dll.
I am on windows 7 and using Internet Explore 9.
Exactly what were you searching on when the crash occurred? Also, is this an indexed folder?
I was searching for a missing folder on a network drive. It is not an indexed folder. The network drive is about 1.3 T bytes.
Roland
V8i SS4 v.08.11.09,829AECOsim BD V8i
I do not see Bentley Dgn Reader for Windows 7 in All programs or in the installed list of programs:
Reggie,
Should I install DGN Reader for windows 7 to see if this solves my issue? Is that what your suggesting?
I was checking to see see if you had DGN Reader installed. It appears that you do not. It is not necessary to install this at this time.
Try doing the search again but make sure your view is set to "Details" and not to "Icons". I want to remove the thumbnails when doing a search.
Same windows explore crash with details.
Any other ideas? Should I open a ticket with Bentley support?
The problem is caused by the Bentley DGN IFilter that was installed as a component of AECOSym Building this component is deliever with all platform products. This issue has been files addressed in TR#24090.
To work around this issue do the the following:
In Windows Explorer:
1. Go to Tools>Folder Options>Search tab
2. Turn off option to "Always search file names and contents"
3. Run search
