[V8i SS3] How to Load a Windows application/file from MicroStation
(Posted on Behalf of Be Communities member)
MicroStation V8i (SELECTseries 3) 08.11.09.357
I'm looking for a command to put into a MenuBar item, where I can open a specific text file, located in the dgnlib folder. I don't want it to be edited, so. maybe I just call and open a pdf file.
  • From the MicroStation Help > Contents:
    docs.bentley.com/.../ustnhelp1821.html
    When you create your menu use the key-in % <executable_file_spec>.
    For example, keying in %notepad starts Notepad.
    For your specific question an example would be % <path to PDF> and this will open the PDF upon selection from the menu.  Example: % C:\Documents\test.pdf.
    You can also use a configuration variable in the path similar to this:
    _USTN_TEST=C:\Documents
    Key-in: $ % $(_USTN_TEST)\test.pdf
    Tamicca Sellars
    MicroStation Product Manager
    Answer Verified By: Tim Hickman
  • Strangely the %notepad worked great as stated. I have been wanting to open the snippingtool and have tried the %snippingtool, %snippingtool.exe, %C:\Windows\system32\snippingtool,
    %C:\Windows\system32\snippingtool.exe all the examples end with the picture below
    sure would appreciate any input I also tried the rd=........ as above and more failure. I have searched
    and verifed the path is correct and the file resides there
    Version: MicroStation V8i SS 10
    RJB Phillips III (Richard) Praise the Lord for His Mercy and grace in Christ Jesus
