Dear Sir, I have troubleshooting with Bentley product on one of my company machine.
When i installed Microstation, the error message appear as the screen shoot:
1-Error=1603
2-When I uninstalled the projectwise or microstation, the Error appear
What is the problems related this? and please let me get the real resolutions about this issue.
This seems to be an error with the Windows Installer. It has nothing special to do with the Bentley Product itself, but should occur on any application that uses the MicroSoft Windows Installer at all. There are a lot of possible reasons, from insufficient rights to the destination folder up to the usage of encrypted drives. See the MicroSoft solutions for this error when you google for "installer error 1603". Nothing that anyone outside your company might resolve.
For error 2738 worth to check the following sollution: communities.bentley.com/.../internal-error-2738-installing-pw-explorer.aspx
and this one: communities.bentley.com/.../41200.aspx
or: blogs.msdn.com/.../3151752.aspx
"....It has nothing special to do with the Bentley Product itself, but should occur on any application that uses the MicroSoft Windows Installer at all. "
I am using Windows 7 professional Service pack1, Norton 360 and installed prerequisites yet Error 1603 won't allow me to install a certified for this environment Bentley product - what did I missed ?.
Bentley post-prerequisites?
I have disabled all AV services leaving computer wide open for 15minutes, than 1 hours etc.
I was trying to sign up and finish PhD in information technology but my family took over all my spare time.
1) Entry in BentleyInstallationlLog indicates that:
Modifying Property: DATABASE="C:\Windows\Installer\7feb1.msi";Date="2014364";
Command exited with code: 1603;Date="2014364";
2) C:\Windows\Microsoft.NET\Framework\v2.0.50727\aspnet_regiis -I
C:\Windows\Microsoft.NET\Framework\v2.0.50727\iisreset won't allow access "... you must be an administrator of the computer...." well, I am
3) Can someone help me to finish this weekend project and install a Microstation
4) In the past I have managed to install two dozen of other programs as required. I have also spend a time reading Bentley installation guide for MicroStation_08.11.09.357
5) please help me, save me
Did you right-click on the installer and pick Run As Administrator?
Marc
Sorry for my lately because i was fixed by any ways. I had tried several times by following the instructions from here and it not saved me so the last way only tried to find out on other ways that i get from internet.
It fixed me.
Thanks you
