Automatic MS_RFDIR Creation
I am working on a major revision to our network workspace and am trying to build the MS_RFDIR configuration variable with our knowing all of the possible directories that will need to be included.
I have a base set of directories to include in this variable but some of our design build projects have additional directories that need to be added as the project progresses.  I don't know the directory names until the files are recieved from another design firm and I don't want to continually edit the PCF to add the new directories
Example:
Base Directory:  /DesignBuild/
                      /DesignBuild/CompanyA/  #Additional subdirectory added after creation of pcf file
                      /DesignBuild/CompanyB/  #Additional subdirectory added after creation of pcf file
Is there a way to have all subdirectories(CompanyA and CompanyB) of a known directory (DesignBuild) added automatcially to the MS_RFDIR without using VBA or another other programming language?
Jason Brame
Microstation V8i SS2:08.11.07.443
