Variable _USTN_DEFAULTUSER_CFG_FILE - Not Updating When Changing Users and Projects
I am attempting to setup a network workspace that incorporates some of the settings of the Bentley Civil workspaces. However, I need the result to use my user and Project. As I recall, the software updates the cfg pointed to by the variable _USTN_DEFAULTUSER_CFG_FILE so that when you launch a new session, it has a default users and project to load. Since setting up the workspace, I cannot get the software to remember the last used user and project.
I open MicroStation and it is set to one the examples user. I then change it to one of our users and a standard project. However, if I open a file, the CFG settings are still seeing the example project settings. I can Close (Ctrl+W) and confirm my current user and project, but the old settings from the examples are still being used. If I then exit and start a new session, it again defaults to the  examples.
Parents Reply Children
