We are trying to standardize our MicroStation V8i configs, so each of our offices is using the same set/s of support files for plotting, levels, colors, linestyles, etc.
With past employers, my workstation was always set to point to the server support files relating to standards, so that all drawings, no matter where they were produced or plotted, would look identical.
I'm told by another user, that this is impossible and each local computer must have all the files set on their hard-drive, which he says could take up to 2 weeks of work for each new project to set up standards. This makes no sense to me and would defeat the purposes of creating company wide cad standards for MicroStation.
Can't this still be accomplished? If so, where can I find the proper procedures?
My advice would be to look at using a custom cfg file that can be placed in the appl directory for each MicroStation install. There are many ways to achieve this, including using your users login scripts.
Have a read of:
communities.bentley.com/.../cfg-my-way-how-to-configure-your-own-build-bear-39-s-alternative.aspx
for more on the custom cfg check out:
communities.bentley.com/.../build-kick-off-ustn-site.aspx
A little bit of advice on how to set up your site cfg files:
communities.bentley.com/.../tech-tip-config-loading.aspx
There is a lot more content of setting up builds so please feel free to have a look around and let me know if there is anything else you'd like to see covered:
communities.bentley.com/.../default.aspx
Answer Verified By: Sherrie Garnett
Excellent suggestions Bear & Jeff! :)
