This question comes from GLENCORE:
I'm interested in improvement in check sheet print out. If there was pictures at the time the report was done, are the pictures included when printing inspection report?
There have been several requests recently about including photo's in inspection reports so I'm bringing this forum back into circulation. As per Stacy's comments below, previously customized inspection reports may not see photos in the print-out of those custom reports post upgrading in version 7.8, so you may need to contact Bentley Services to update those custom reports or choose to delete them and use the out-of-the-box inspection report. The out-of-the-box inspection report print-out in version 7.8 does allow end-user to select specific photos that were attached to indicator readings on the related checksheet. This process is fairly straight-forward, on the Inspection Report go to the Inspection Report view > Photos tab and click on the browse button to view all photos linked to indicator readings referred on the report and select those that you wish to include in the printed report.
From the Inspection Report menu select Print > Inspection Report.
