I created a bunch of indicators which will finally, be never use. Unfortunately there is one reading in each one. Is there a way to delete those indicators ? At least, is it possible to change the indicator type, so I can use those somewhere else ?
Ghislain Generally you should be able to simply delete the indicator. The readings will be deleted at the same time. There are a few situations where the deletion will fail. For example if any of the readings had an alarm which was acknowledged with a work request or task, you can not delete the indicator. Have you tried deleting the indicators? As for changing the indicator type this is not permitted once readings have been entered for the indicator. Changing the indicator type would result in a situation where the first reading related to one "indicator" while the following readings relate to the new use of the indicator. This could be misleading if the someone was reviewing the indicator history in the future.
View online
If you encounter issues clicking "View online", check here.
You received this notification because you are subscribed to the forum. To unsubscribe from only this thread, go here. To unsubscribe from a forum, please see this note.
Flag this post as spam/abuse.
