A template has been created (say that the action plan of failure mode 1.1 contains one indicator A, with states A1 and A2) in V7.4. Next, the template is copied to an asset (MTA) (say MTA1). Subsequently, the states of the indicator are changed (so that indicator A has states A3 and A4). Finally, MTA1 is copied to a new MTA (MTA2) (expecting that indicator A has states A3 and A4). However, it seems that MTA2 has the state values that belong to the template, namely A1 and A2.
Is there a box that can be unchecked so that the indicators do not have to be adjusted manually. Remark that the test and training clients do not show this occurence?
Looking forward to hearing from you.
Answer Verified By: David Crozier
