Product: EXP 6.2.4.106: Would like to know if an Indicator can access Asset criteria. Example: Would like to create a "Risk" indicator that multiplies the asset's CPN (consequence priority number) times the numeric output of a "Health" indicator.
"Risk" indicator for a given asset would need to directly access the CPN number of that same asset in order to generate an overall Relative Risk value.
Answer Verified By: David Crozier
