The user must exist in the application before the service will start successfully.
If the service is installed under user service account. You must add both a user and an employee in APM for the service. If you are using Local system, the user name must be the Computer_name$. In the employee definition, provide a valid email address.
For more information see the installation guide under "server deployment" section.
