Myself and our support group are attempting to upload assets into our APM 7.5 TEST environment. We've been unsuccessful to date with the process. It appears that a batch job needs created to kick off the upload. We've spent some time trying to create but no success to date. Has anyone successfully used the mass upload feature in 7.5 for assets and perhaps provide insight into the process and requirements?
Hello Mark,
Have you checked the Data Loading section of the Administration Guide in the R7.7 Online Help?
If this does not assist, and you do not hear from anyone else on the forum, please submit an Support Request for personalized attention from one or our Support Representatives.
Giselle
What have you tried and what happens?The basic process is very simple:1. Set up a app server instance that supports the APMJob Service Provider. Start it.2. Create an Excel spreadsheet with your Asset data.3. Import the Excel spreadsheet (this will create a Process Job but not a Process Batch)The app server you configured will then process the file. Generate staging records from the data in the Excel file, process them and create Assets.
