One physical server running two separate server manager instance
I've added a second server manager instance on a physical machine.
  1. Copied "ServerAdminBroker" folder
  2. Changed instance name in web.config file to 2nd instance
  3. When browsing to APM server manager site both instances are listed.  However the incorrect instance shows all the servers as stale.
