Ivara.OTAssert File: Cax.cpp(4173) : Failed Assert: oCAX::getStateGroups() - This cax does not have a member - why is getStateGroups begin called
Hi
I'm trying to add comment to work request and when trying to execute the following code
WorkRequestComment wrComment = WorkRequestComment.Allocate(workRequest);
In APM server log window getting error below
01/07/2020 11:30:51 Error [***myuser***] Ivara.OTAssert File: Cax.cpp(4173) :  Failed Assert:    oCAX::getStateGroups() - This cax does not have a member - why is getStateGroups begin called
Comments are saved and you could browse them. But every time error above pops up
Code below
WorkRequest workRequest = WorkRequest.Fetch(12345);
using (var trans = new DBTransaction(false))
     TransactionUpdate truWorkRequestCommentAdd = new TransactionUpdate(workRequest);
     if (workRequest.FetchLock() && truWorkRequestCommentAdd.CanContinue)
          if (workRequest.GetMethodState(WorkRequest.AddWorkRequestComment_M_ID) == oCAXContainerObject.eMethodState.MethodAvailable)
                WorkRequestComment wrComment = WorkRequestComment.Allocate(workRequest,null);
                wrComment.Comment = "Custom comment";
                wrComment.CreatedBy = wrCreatedBy;
                wrComment.CreatedOn = wrCreatedOn;
                wrComment.TypeOfComment = WorkRequestComment.eecWorkRequestCommentTypes.evMiscellaneousComment;
                wrComment.Updates = 0;
                workRequest.AddWorkRequestComment(wrComment);
                wrComment.Persist();
