Hi All,
The problem is not new. When I try to delete indicator it produces the error that there is not all readings entered for the minimum required points...
I tried to mark all readings as incorrect but it does not help.
Did anyone overcome this problem?
Can you please submit a service request so that we can start investigating the issue you are facing?
Yes, I have submitted. Its number is 7001026775
Thank you Aleksander!
We will get back to you shortly.
The SR has been assigned and investigated by me. I've replicated the issue but will limit communication to the SR's email trail only.
Joe
