In my case, I set a triggering rule for the standard job every one month of the calendar days. However, the standard job trigger at different days of the month. How do I configure so that the standard job trigger the work order every 1st of the month?
To start the trigger on a specific date, add a one-time exception triggering rule:
When we set up the Std Job, we use the exception on 1st of the month. However, after awhile the std job starting to deviate to different days of the month. Is there any solution to this issue?
Not really. I believe it depends on when a PM job triggers, but it can get out of sync. Not sure, but probably due to some months having 31 days, or 28 days for February. You then have to set it back manually. It's always been this way. Please enter a Service Request if you need this investigated further.
I see. Thanks for the explanation. Will proceed with a SR soon.
