apm V7.15
What's the way to change the UI language from Chinese to English?
Brian Kong The APM Configuration tool has an option to choose a language for that particular instance/server. Please have a look at the below screenshot for your reference;
The selected language and region will be used in the user interface and for formatting. All clients that connect to this server will use this language.
If the language is not available for the user interface, it will default to English, however, all formatting will be done for the specified language.
Please make a note that, language changes will take effect when the server is restarted.
I hope this answers your question. Please let me know if you are having any queries.
Thank you Tushar, that's great!
