we plan to use quick links to "document enable" an application.
Is there a way to set the default to "launch" instead of "view content" so the users don't have to remember to change it every time?
Hi Sue, im not sure I quite understand the question can you explain it with a little more detail?
If I'm interpreting your question correctly, i think this is what you need to do.
In your web.config find <eB.PlugIn.QuickLink.Properties.Settings>
If the setting <setting name="ObjectMode" serializeAs="String"> isn't present, create it, setting the <value> to "Launch File".
<value>Launch File</value>
</setting>
The valid values are: ‘View Content,’ ‘Edit Content,’ ‘View File,’ and ‘Launch File.’ If the ObjectMode setting is not specified, ‘View Content’ is used.
Eric Rajala | Consultant
Cohesive
Email: eric.rajala@cohesivegroup.com
www.bentley.com
Answer Verified By: Carma De Villiers
