Hello Folks,
If I have an instance of open already open and I click on a hyperlink to another document I get the following error --- "The link you have followed refers to different community than the one that you are log in to. To follow this link and log on to....."
Please see attached screen shot for further details.
Immediate response to this would be greatly appreciated. Thanks!
Roberto is checking with engineering.
Rawlings,
what version of IE are you using on the client? Do you get similar message when you do this from the server?
Address: Bentley | 10052 Mesa Ridge Court Suite100 | San Diego | CA | 92121 | USA
I use IE8 on the client
Hi Roberto,
I hope you are well? Any feedback on the above query?
Thanks!
Hi Rawlings,
I have not been able to replicate.
Can you run the test, but instead of using windows authentication, login as ADMIN ?
