Attributes set up as Multi Value
We have an attribute that we created a while back and been using.  We are now wanting to use it as a multi value attribute. Can we add this functionality after the fact?
  • Hi Alex,
    off the top of my head, I don't think this can be done if you already have values on the field. The single attribute values are stored in a different table than MV attributes, so to do this you might need to do some scripting to convert the older attributes into an MV attribute.
    If you have a test environment, you could test by adding an attribute as single, adding a value to a few docs, then try to enable the MV flag and see if it allows you to do it and if older values are still present.
    thanks,
    Address: Bentley | 10052 Mesa Ridge Court Suite
    100 | San Diego | CA | 92121 | USA
  • Has this issue been resolved? If so, could you please close the issue by selecting "This helped me"
    and "Verify Answer". If not, please let me know so I can follow up on this issue.
    Carma
    carma.DeVilliers@Bentley.com
    Answer Verified By: Carma De Villiers
