Hi Bentley and the Forum,
We are working to get our eB instance v15.4.1 to be external via a gateway and we can log into eB all OK but we are finding that we cannot see our search folders and reports within the Explorer menu. It just appears blank. Do you have any idea why this could be happening and what needs to be done to fix it?
Many thanks,
Julie
Hi Gintautas, hope you are well.
We have some folders and some search reports on their own but both don't come up. It just appears blank in the box where the "tree" should be. No, they are standard eB eQL type reports. Thank you!!
Hi Gintautas and the team,
Since this request for help, we have done some testing of our own!
We have found that this explorer issue where the search folders/reports do not appear occurs on our personal machines where either Windows 7 64-Bit IEv11 or Windows 7 64-Bit Firefox v33 is used. It actually worked OK with older versions of IE and older versions of the Windows platform on our personal machines.
Has eB Insight v15.4.1 been tested on Windows 7 64-Bit machines?
Also, has eB Insight v15.4.1 been tested on different versions newer than IE8?
We want to see if our eB will only work properly with IE8 or less on our Windows 7 64-Bit machines.
Many thanks, best wishes,
Hi Julie, here is the list of the supported software for v 15.4.1. There are known issues with IE 9,10,&11 for v15.4.1 so they are NOT supported. IE11 will be supported in our upcoming v16 in December.
-Derek
Hi Julie here is all of the supported software versions for 15.6.1. I made BOLD the web browser section for you.
Supported Operating SystemsAll eB server modules (those found in the ...\eB\Server Installation folder) are supported on these server operating systems:
Windows Server 2008 R2 SP1, Standard and Enterprise Editions, 64-bit Windows Server 2008 SP2, Standard and Enterprise Editions, 32 and 64-bit Windows Server 2003 R2, Standard and Enterprise Editions, 32 and 64-bit All eB client modules (those found in the ...\eB\Client Installation folder) are supported on these client operating systems:
Windows 7, 32 and 64-bit Windows Vista SP2, 32 and 64-bit Windows XP, 32 and 64-bit (SP3 for 32-bit; SP2 for 64-bit) Note: eB Director can also be installed on supported server operating systems if needed, however please note that only limited testing has been done in this area. Back to top
Virtualization SoftwareeB is supported for use in virtual environments, however Bentley does not certify eB on any specific virtualization software. While eB testing is regularly performed using virtualization software, the individual eB modules are tested with a focus on the operating system, not the specific virtualization software running the operating system.
Back to top
Supported DatabasesMicrosoft SQL Server 2008 R2 SP2 Microsoft SQL Server 2008 SP3 Microsoft SQL Server 2005 SP4 Oracle Database 11g (11.2.0.3) - using 11.2.0.3 Client Oracle Database 10g (10.2.0.5) - using 11.2.0.3 Client Note: It is recommended that you use the specific versions listed. Incremental updates are likely to work as well, but are not recommended as they have not been tested with this release.
Supported ApplicationsApplication Supported Versions ProjectWise Explorer (64-bit only) V8i (SELECTseries 4)* ProjectWise InterPlot Server V8i (SELECTseries 4) MicroStation V8i (SELECTseries 2), V8i (SELECTseries 1) AutoCAD (64-bit) 2012 (SP2), 2011 (Update 2), 2010 (Update 2) AutoCAD (32-bit) 2012 (SP2), 2011 (Update 2), 2010 (Update 2), 2009 (Update 3) Microsoft Outlook (32 and 64-bit) 2010 (SP1) Microsoft Word (32-bit only) 2010 (SP1) SharePoint Microsoft SharePoint Server 2010 (Standard or Enterprise)Microsoft SharePoint Foundation 2010Microsoft Office SharePoint Server 2007 SP1Windows SharePoint Services 3.0 SP1 Kofax Capture 10.0, 9.0 Brava! Desktop 7.1 Brava! Enterprise (ActiveX version only) 7.1
Notes:
The eB ProjectWise Connector requires the 64-bit ProjectWise Explorer V8i (SELECTseries 4), which in turn supports connection to: ProjectWise Integration Server V8i (SELECTseries 4) ProjectWise Integration Server V8i (SELECTseries 3) ProjectWise Integration Server V8i (SELECTseries 2) ProjectWise Integration Server V8i (SELECTseries 1) See Items No Longer Supported for a list of applications no longer supported as of this release. Back to top
eB Core Server (Application Server) RequirementsProcessor Pentium class processor. 3 GHz or better recommended Memory 4 GB RAM or more recommended Hard disk 512 MB of free hard disk space for install Operating system See supported server operating systems Database See supported databases Network Windows networking configured for the TCP/IP protocol Software Prerequisites Microsoft .NET Framework 3.5 SP1*Microsoft .NET Framework 4.0*Windows Identity Foundation (WIF), KB974405 (delivered with eB)Oracle 10g or 11g Client (if Oracle is your database)
*Both versions of .NET Framework listed are required for eB Core Server. eB Document Creation Service also requires Microsoft Word 2010Microsoft Excel 2010 eB Print Service andeB Rendition Servicealso require ProjectWise InterPlot Server V8i (SELECTseries 4), which itself requires:GhostScript - to create PDF renditions of Word and/or Excel filesMicrosoft Word 2010 - to create PDF renditions of Word filesMicrosoft Excel 2010 - to create PDF renditions of Excel files eB FTR Service also requires Microsoft Indexing Service - only needed if using SQL Server, and must be on the SQL Server computerAdobe PDF iFilter - only needed if using SQL Server, and must be on the SQL Server computer
Note: eB FTR Service can be, but does not need to be installed on the SQL Server computer License eB Core Server requires an eB Information Manager license.Other services require additional licenses.
eB Director RequirementsProcessor Pentium class processor. 1 GHz or better recommended (32-bit (x86) or 64-bit (x64) processor) Memory 1 GB RAM (for 32-bit eB Director)2 GB RAM (for 64-bit eB Director) Hard disk 130 MB of free hard disk space for installation Operating system See supported client operating systems Network Windows networking configured for the TCP/IP protocol Software Prerequisites Microsoft .NET Framework 3.5 SP1Windows Identity Foundation (WIF), KB974405 (delivered with eB)Brava! Desktop 7.1 - to view files in eB without having to install their native application. License Requires a Bentley Passport license.
eB Web Applications (Web Server) RequirementsProcessor Pentium class processor. 3 GHz or better recommended Memory 4 GB RAM or more recommended Hard disk 512 MB free hard disk space for install Operating system See supported server operating systems Network Windows networking configured for the TCP/IP protocol Software Prerequisites Internet Information Server (IIS)Microsoft .NET Framework 3.5 SP1ASP.NET v2.0.50727Windows Identity Foundation (WIF), KB974405 (delivered with eB)Brava! Enterprise 7.1 (ActiveX version) - required to use the View in Brava feature (lets users view files without the native application)
*Brava Enterprise is not required to be installed on the eB Web Server computer itself. Supported browsers Full support: Internet Explorer 8, 9
Limited support: Internet Explorer 7
Google Chrome (latest)
Mozilla Firefox (latest)
* Latest updates are expected to be installed* eB Web operations that use ActiveX require Internet Explorer 8 or 9* 64-bit Internet Explorer 9 requires a manual install of ActiveX controls using the eB Web Client Components installer License A Bentley Passport license is required for each user connecting through eB Web.
eB Engineering Designer RequirementsProcessor Pentium IV class processor. 500 MHz or better recommended Memory 512 MB of RAM or better Hard disk 130 MB of free hard disk space for installation Operating system See supported client operating systems Network Windows networking configured for the TCP/IP protocol Software Prerequisites Microsoft .NET Framework 3.5 SP1Brava! Desktop 7.1 - to view files in eB without having to install their native application. License Requires a Bentley Passport license.
Answer Verified By: julie_beck
