I am using 15.5.1 with oracle. I am trying to make the context menu expanded by default for a specific document class. I was able to make the work order menu expanded by default by going into the layout editor and unchecking the "title only" check box. Purge the cache several times and reload eb web. When I goto a specific document in the doc class I get the attached error. If I go back and recheck the "title only" check box I contunie to get the error. I have to import an export of the structure before the change to get the error to go away. Thanks for your help.
Alex Talbott
