I am using Document Import Configuration Utility to create an eB document & relate it to a Grouped Virtual Item. The document created OK but not related to the Virtual Item. The following error message "Adding Grouped Virtual Items failed. Not all grouped virtual items are added to the document. Error: Sequence contains no matching element" is logged
Can you tell me what the "Sequence contains no matching element" means?
Steve
I am using eB 15.6.1.115
Please find attached the import xlsx, ini file
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/343035/ini1.ini
Hi Steve,
I've attached simple configuration file. Please as Admin user try uploading documents using it and send us log files.
NT
