Guys
I love the quick link url function it means I can send docs to those to technologically challenged to log in and find docs but is there a way I can tick a set of docs and export the links and metadata into an excel spreadsheet as just a general user?
Cheers
Spadge
If you noticed how the quicklinks are built from the quickURL, you can use this to create your own custom report or search column in eB like this sample eQL:
http://your-portal-name/Search/QuickLink.aspx?n=XYZ-123123&t=3&d=&sc=YOURSCOPE&r=5&i=view
START WITH Document
SELECTId,Code,Revision,'http://your-portal-name/Search/QuickLink.aspx?n=' + Code + '&t=3&d=&sc=YOURSCOPE&r=' + Revision + '&i=view' QuickURL,Name,Scope.NameWHERECode = 'XYZ-123123'AND Revision = '5'
From here you can customise the eQL to suit your needs then use Download All Results to download to Excel.
Hope that helps.
Answer Verified By: Carma De Villiers
