Hello Folks,
I have installed eB 15.6.1 and I'm currently having problems to get PW Connector working. I have configured PW connector as instructed by the eB installation manual but is still not working as expected. Also, I have deployed a SQL Server Agent job which should synchronize PW PDF folders in eB but that is also not working.
I have to manually register each file as an enterprise document in Director and then manually synchronize the folders before the files can move from PW into eB. I have attached screen shots for your perusal.
I urgently need help to resolve this issue as it is causing problems for my client.
Thanks in advance.
Kind regards,
Rawlings
Answer Verified By: Carma De Villiers
